- Sep 16, 2019
- Age
- 40
- Bayville, New Jersey
- Seafarer
As I am looking to replace the battery cables and the wire running to the helm, I would like some advice on how best to wire the new fuse panel and common busbar that I am replacing. I ended up ordering the Blue Sea System Common Bus Bar 2300 (150Amp) and Blue Sea System Fuse Panel 12 circuits with negative bus 5026. Per Grady, these are the replacements for my 2000 228.
I started reviewing my current setup (pics attached), but was a little confused. Below is what I noticed so far.
- There are 3 positive terminals going to the current Fuse Panel. My assumption is that 1 is from the breaker by the battery, 2nd is going to the panel at the Hardtop, and 3rd is an unknown right now.
- There are 3 negative terminals running from the Current Fuse Panel. Similar assumptions as the above, with the 3rd still being an unknown
- My common busbar has 5 terminals, but none are on the stud, which seems odd. Also, I need to break apart all of my wires to figure out what they are as the common busbar wires get lost in the harness. From what I can tell, none go to the fuse panel.
My "electronics", as of now:
- Spreader lights + hardtop spotlight
- VHF
- CD + Radio
- GPS/ Fishfinder (will be replaced by new 7in MFD)
- Depth Finder (will be replaced by a 2nd 7in MFD
- Radar
- Usuals (Bilge pumps, livewell, etc)
- Fuse Panel and Busbar under steering wheel (replacing these)
- 2nd Fuse Panel in hardtop (not replacing)
Questions
1. Any idea what could be the 3rd positive terminal on my fuse panel? What should I look for?
2. What typically should be fed to the common busbar?
3. My plan is to basically match the current setup on the fuse panel except I am unsure of what I should do with the negative. Should I continue to have all grounds go to the same stud on the fuse panel or have the fuse panel go to the common busbar and have them ground there? Obviously, positive and negative on each device will stay on the fuse panel.
- VHF
- CD + Radio
- Radar
Questions
