- Sep 1, 2013
- Allentown, PA & Friendship, ME
- Offshore
Here's another way to think about that hour glass. Imagine or actually do this... Take a piece of a wood and drill a hole through it. Now, take a drill bit that is about 50% bigger than the drill bit you used to drill the hole. Use that drill bit and drill just far enough to make a "counter sunk" hole. Meaning, you just create a chamfered edge around the circumference of the hole. Do the same thing to the other side. There's your double-end plug. But, as I mentioned above, this might be overkill for this situation. The epoxy is going to make a very tenacious bond to the fresh fiberglass.
Another way to think of it... put two funnels together to make an hour glass shape.
Soaking the wood... I've never used the stuff Dave is talking about, but from my experience, it takes AT LEAST 3 to 4 coats of epoxy till it stops soaking in... indicating it is soaking in pretty far - certainly more than enough for this situation. But without having first hand knowledge of the sealer, I certainly won't comment on whether the epoxy is soaking in as far as the sealer.
For me... and I suppose a lot of this is really what works best for ourselves... I'd rather epoxy the wood in place, then drill my mounting holes in one shot through both the fiberglass/epoxy and the wood.
EDIT: Looks like I was typing at the same time you turned the lights on regarding the hour glass!
