I have a 2000 model 40hp yamaha 2 stroke on a tender, obviously not the motor off my Grady. This may not qualify for a question on this site but I thought with such a large knowledge base on outboards here, correct advise will be easy to find, and the information should also qualify for the motors we use on our Gradys
The motor which I've just bought was neglected from lack of use to the point where the steering shaft was siesed on the motor. I heated the area behind the motor with a head gun and pumped heaps of new grease into it top and bottom, as advised by local mechanic, to melt and remove the old gummed up grease. This didn't though get the motor turning till I had to take to the steering arm with a fibre hammer (with the steering rod removed). It finally freed up and after a few tubes of freshgrease works well.
The problem: before I did this the electric trim worked OK. After the heating and hammering it was initially working but with a different rattling type sound, and then after a couple of runs in the boat it just stopped altogeather. The solinoid on the LH side of the engine clicks when pushing up on either control and it kinda makes an attempt to go down (drops an inch or so).
With the realease screw undone the motor pulls up but with a bit of effort, free right at the bottom but then gets a little stiffer, it has no problem dropping down.
Pump etc looks just like a smaller version of whats on my 225's
Possible problems?
Whats the process of elimination?
what parts are reconditionable or throw away?
Any tricks to removing anything I'll need to get looked at?
Reason I don't simply take it to a dealer is I'm a little isolated living on an Island. Help appreciated
Possible problems?
