2005 Yamaha 250s with the round guages. My GPH works sporadically and MPG shows 0.0 continuously. The trip meter also stopped working. All three worked prior. Any ideas on where to begin? All the other guages work fine. Thank You......
be careful blowing air into the tube. If the tube is clear but the actual hole in the LU is plugged, it is possible foe the tube to blow itself off of the connection. In that case, you have to drop the LU to reseat it.trapper said:HB Steve. Easy to clean the the hole in your port engine yourself to be sure. Take a drill bit the same size as the hole and spin it by hand, go in as far as the bit allows, that should clean it out. Then check at your gauge (it is a clear tube) to see it your are getting water at the gauge. If still an issue remove tube from gauge and blow air into tube backwards to clear it. Have had to do it a few times as drying salt water can create a crust and debris in the entrance hole. Good luck. Cheers, trapper
