Yamaha Fuel MGMT Gauge
wind on
Ocean City, MD
I recently lost the display in my Yamaha Fuel Management Gauge. It only has partial displays that make it unreadable. I believe the unit itself is working fine, its just a matter of the readout. Has anyone had any similiar issues. Any suggestions or I am doomed to puchasing a new unit. Any feedback would be greatly appreciated.
Capt Bill
First State
What year and model engines? Do you have twin engines? If so, try swapping them and see if the problem follows. If a single, I would check the wiring for a loose or missing ground connection or other wire to the gauge. If someone here has a diagram for your gauge, you might be able to do some voltage checks at the little push-on connectors.
wind on
Ocean City, MD
Thanks for the reply. I added the gauge to my 2001 GW 209 in 2002. Single Power, a 200 HPDI which I repowered in 2005. I will poke my head back under the console and double check the connections.
ahill
Manatee Pocket, FL
Marine connection in Ft. Pierce has a lot of new ones. A friend just bought one new in box for $197.00
