- Mar 23, 2019
- Age
- 68
- CT Coast
- Sportsman
My running lights weren't turning on, I traced the problem to a faulty 10A dashboard circuit breaker which was only putting 6VDC through. This is a small rubber button next to the switch on the dash. I tried removing the dash but the 6 mounting screws have frozen, the first one snapped right off.
Can this be replaced from the front, if I remove the rubber cover will there be a small locking ring which will allow me to remove it from inside the console? Does the rubber cover just pry off?
Also, my horn switch is wonky, are these switches GW specific or available elsewhere? Can this also be done from the front?
thanks,
Rob
thanks,
Rob
