I think that you're looking at the wrong model of Suzuki's. Per Google, each of the OP's 2006 ETEC 250's weigh approximately 516-530 lbs depending on the model, shaft length and so forth. Comparatively, a brand new Suzuki DF200A weighs 531 lbs for the 25" shaft with the digital/fly by wire controls. Not sure if you're looking at the DF200T, which has the mechanical controls and weighs 606 lbs a piece for the 25" shaft version? Either way, I doubt the OP would feel much of any difference at all back there with the DF200A's weighing essentially the same as his current ETEC's.
To the OP... here's the thread from Skunk Boat on his repower, check it out.
More than I would thought it would be. I like the weight reduction for sure. How do you use the boat? If you ok with the lower performance and better price point, the weight reduction is the way to go.
In my case, I'd go for the 200s. but you may want the extra ponies.
Ok guys, I think Ive decided against the 200s. Don't want to risk being underpowered and losing the torque of the V6. I typically run with full gas tanks and pretty loaded down, so want the power when i need it. Just need to make a decision between the mechanical 225 and digital 250. I tested the boat over the weekend and put 175lbs on the transom and it didn't affect the water line much. water was barely kissing the bottom edge of the scupper opening. maybe sunk the stern by 1/4" to 1/2" if anything. I did see a guy who did 250s on the stepped hull and his boat seems to sit okay in the water. See link. My question is, is the FBW worth it. The digital 250s are another 6k. And thats a lot of gas money or other upgrades for the boat. Is the smooth shifting and being able to use one throttle with twins really that big of a deal?
I think that question is one only you can answer. IS FBW nicer? Oh my gosh, yes! Every aspect of usability is nicer and easier. The only downside is if the system craps out - but generally speaking, FBW is very reliable - but make sure you battery connections are good/clean as FBW is voltage sensitive.
Mercury started using it back in the early 2000's and it been a good, reliable system. I don't know how long Suzuki has had it, but I would imagine it should be similar to Merc. The question is... is the $6K worth it to YOU? Or are you plenty happy with 'ol school? Nothing wrong with 'ol school, either!
Does it bug you to constantly have to sync engines manually? Does the lack of precision around the dock piss you off? Do you plan to keep the boat for more than 7 years?
$6k is a lot. I think on the 4 cylinders the total difference was about $2k for twins. I would think rigging digital would be way less time consuming. Does the price reflect that?
By chance have you priced Hondas?
I wouldn't say any of those things bug me. I haven't ever experienced the fly by wire. I have managed without it obviously. I do plan to keep the boat longer than 7 years.
My mechanic friend who works at a dealer is giving me a deal on the suzukis. So no I haven't priced hondas. Not really interested in them. Basically the quote I received for the 250s digital is 6k more than the mechanical 225s. Going to select one or the other. Just keep going back and forth and hoping some people on here might sway me one way or the other.
My 265 is wide and heavy. It carries 250 gal of gas and 300 lbs of ice...often....on 3 hr runs to canyons.
I am very happy with the DF200APs. Would DF250APs be faster and get even better fuel economy, yes. But the weight and price are a problem.
IMO get the fly by wire. Would you buy a car with a cassette player and crank windows? No! Its 2026 bro... join the 21st century.
I'm surprised you're getting 1.8mpg. Cruising normally at over 5000rpm seems a little hard on the engines to me though. I do get the 21st century argument for sure. New 225 V6s just seem like they would provide more torque and get better mileage being able to cruise 30-35 at a lower rpm.
Do you have any torque issues staying on plane at low rpm in rough conditions? How's the hole shot?
Once we got the props right, there is no problem out of hole or in a crazy inlet against the tide. The 4 blade props were a must.
The zuke i4s are geared differently than any motor you are used to. Running at 5k is normal. You are swinging a bigger prop and have the torque to do it.
The 265 wants to go 28mph or more with hands off the throttle.. Below that in snotty conditions you have to be on the throttle to maintain speed. I can run it as low as 21mph but there is no momentum to power thru swell. The boat thumps the waves. You have to work it. I previously had 225 OX66s. They had a higher top end. They didn't keep the boat on plane any better at slow speeds.
I find faster is better in snot (to a point). I have worked my way home for 2 hours at 24-25mph but 28 is the magic number if you can find a groove. The 272 might be a little different?
I have the DF200APs for 5 seasons (6 month seasons) and I'm at 998 hours. No problems. There are several 265s with DF200APs and nobody complains.
Yes, no doubt that V6s will perform "better". But I can cruise at 33mph no problem. I have no desire to go over 40mph.
The 225s are their very old block. Mechanical only. I think maybe the choice of gauges is different too? Its a relic that is offered at a discount with no options.
I'm surprised you're getting 1.8mpg. Cruising normally at over 5000rpm seems a little hard on the engines to me though. I do get the 21st century argument for sure. New 225 V6s just seem like they would provide more torque and get better mileage being able to cruise 30-3at a lower rpm.
thanks for the detailed response. Seems like you really like the 200s. Just wonder if it's an equivalent performance comparison between the 265 and the sailfish.
What are your thoughts on the fuel economy of the 200s vs the 225s. You think the lean burn tech of the 200s at 5000rpm cruise beats the 225 at lower rpm?
My dealer has the new smg4 gauges on the quote for the 225.
IDK the specs on a '95 272. Add the motors, fuel , ice, gear and hardtop and the 265 is close to 10k in the water. 9'7" beam. its a heavy boat.
Motors are on the transom. no set-back, no bracket. My 2000 has a 22 degree deadrise(another reason it doesn't like to go slow)
They clear the water in stowed position. I NEVER use trim tabs.
Does the 272 have a bracket?
I'm guessing that 4 stroke V6s will get better fuel ecomnomy but idk. The 200s made me so happy after the OX66s that got 1mpg.
If money was not a problem and transom weight was not a problem, I would probably have got DF250APs. They would probably get better than 2mpg.
But I am extremely happy with these motors.
They clear the water in stowed position. I NEVER use trim tabs. View attachment 38826
The sailfish seems similar in specs.
9'6" beam
32 gallon freshwater
202 gallons of fuel
5500lb dry weight
The 272 has the euro transom. So it is the stepped hull before they took the running surface all the way to the transom in 2000, I think. Which they did to add more buoyancy to the transom to accommodate the extra weight of the new 4 strokes coming out at the time. I was also considering the 250APs but as you said they are substantially heavier and a lot more money. Plus they require 89 octane, so the extra cost of fuel erodes some of the fuel savings.
Seems like your engines are a huge improvement over what you have had in the past and your praise of them is making my decision a lot harder!!! haha. Right now im getting 1.3 with the etec 250s.
There is a guy with a 1997 sailfish. Same hull as mine. I found him on you tube. He put the 250APs on his boat and said he hits 52mph top speed and cruises 30mph getting 2.1mpg average. I thought that was pretty amazing for his setup. Not like i would ever go over 40 but being able to cruise at such a low rpm and get that fuel economy is pretty incredible. Thing probably flies out of the hole with the 4 blade props.
I was thinking middle of the road with the V6 225s. Still have substantial power and low end torque and possibly similar to better fuel economy than the 200APs. But just at the sacrifice of the electronic shift and motor syncing. Out the door price for the 200s I was quoted 44.1k, 47.2k for the 225s and 53.5k for the 250APs. I did find a guy on here and tried to DM him about his sailfish that he put the 200s on but haven't heard back yet. Tough decision weighing better performance vs high tech bells and whistles.
It sounds as though you're trying to get every bit of performance/fuel economy out of the boat as possible whilst also trying to conserve as much weight as possible? Of which, if that's the case then I'd go with Mercury. I believe you said you're in San Diego? Here's a place called Sunset Marine, which is a Mercury dealer and has the Mercury 250 FourStroke model on sale for $22k a piece, down from $28,110. The Mercury 250 will weigh in at 527 lbs a piece and still have the digital/fly by wire controls. Or, if you want to go the 225 route, the Mercury 225 FourStroke is about $800 less a piece and only weighs 475 lbs per outboard. Looks like Mercury also has a 7 year promotional deal going on right now to where if you buy before March 31st, you get a 7 year warranty. Not sure if your above quoted prices are just for the outboards or if they include installation as well, but the Mercury 225'-250's would be the same price or less as the Suzuki 200's and considerably less than the Suzuki 225's-250's. Not sure what Sunset Marine charges for installation, but I can't imagine it would be a total of more than the $53.5k for the Suzuki 250's that you quoted. If I was in the same boat as you, pun intended, the Mercury 250's would likely be my first pick right now. Lastly, if you're wanting to stick with Suzuki, Sunset Marine has the DF200 for $18,260 a piece and they have the DF250TX for $22,631 a piece. Doesn't look like they've got the pricing for the DF250AP on their website, or they just don't have it in stock, but those prices also look to be considerably cheaper than whoever you're quoting above. Either way, it sounds like Sunset Marine has considerably better pricing than what you mentioned above, and you could always ask about the Suzuki DF250AP, or the DF225TX if you're considering going that route as well. And no, I don't have any affiliation with Sunset Marine.
Mercury 225 HP FourStroke Outboard – Powerful and Efficient from Sunset Marine, San DiegoUpgrade your boating experience with the Mercury 225 HP FourStroke outboard, available new at Sunset Marine, San Diego County’s premier Mercury dealer. Designed for larger center consoles, skiffs, and offshore f
The Suzuki DF250 outboard motor offers several benefits, making it a popular choice for boaters: Performance and Power:Strong Performance: Delivers impressive power and performance with its V6 engine and features like Variable Valve Timing (VVT) and Multi-Stage Induction.Excellent Low-End Torque: Pr
I can't help but think buying twin Mercs would result in further discounts.
When I 1st asked for a quote for my engines, the price was out of line compared to the best prices in Florida. I politely told the dealer that if he wanted to sell engines, he needed to be at least $5k lower to be competitive and I preferred to work with a local dealer. I hit him up a couple months later for a requote. Price came down $4800. SOLD!
Yes thanks. I'm very familiar with sunset marine. Unfortunately after taxes labor props parts and rigging etc the mercurys are still way more money than the Suzukis. By like 10k dollars. If they were in the ballpark I would have already pulled the trigger on the digital merc 225s. Unfortunately my budget only allows the zukes.
