- Mar 5, 2019
- Age
- 57
- Islander
I figured to make a thread detailing the refurb/setup of my "new to me" 2004 Islander 270. I know, not very fancy stuff happening, but maybe someone else will google this, like I did when I found you guys, and be able to garnish some info from it.
The "boat" stuff ties in below.. bear with me.. lol
Been super busy setting up my workshop, so I can prep for the start of the boat top. That is almost ready. The HUGE step forward starts Sunday.
We moved from Round Rock, TX to Cedar Creek, TX because I wanted a shop....and land in that county was super expensive to buy much less pay taxes on. So, I had a 30x30x10 shop built by Wolf Barns. In hind sight, I would / should have made it 40x50x16 and added a 14' door.. but never dreamed of having this boat 2 years ago.. heh
Anyway, adding a few photos of it below.. but I refused to put anything away till the walls were done... as you never go back and fix them afterwards. We built a cabin in the middle of nowhere and used fence wood for the walls as it was cooler than sheetrock.. heh. Did the same with my barn.
Now we have 4 sets of shelves up, and I cut the wood for about 20ft of workbench. Waiting for the rain to stop so I can assemble it. The tops will be 2x12's and 2x8's.
Then we have about 24ft of peg boards to add.
Sunday, we start putting a TON of stuff away, via the shelves. That starts opening up the floor space and the garage. I move the tractor and the mower to the garage.. and daddy gets his fridge, couch, leather chair, TV set up, with an old surround sound stereo system for music.. and all wired cat6...LED lights, ceiling fans, and.. I have a 3-ton brand new A/C unit.. muahahahahah
Anyway, the work bench is for boat and fishing stuff. I have a 10x10 wall section for rods and reels, and can use a few more sections if need be. The boat will not fit.. but I will build a cover for that soon, need the concrete done first.
Anyway, as for the boat:
Rain most the week.. trying to get the workshop done so I can get all the new boat stuff laid out and room to "work".
Got all the new parts for the top, so when it comes in, I have a dozen guys ready to help install it.
WMW Marine called yesterday and they were needing work right now, so may have it out sooner than expected. They said the only hold up will be it usually takes a few weeks for the actual top to be made, but the frame and all the rest will be ready beforehand. They got the check, so they are already working on it.
I have a new radar, radar mount, XM weather antenna, GPS antenna, 2 new VHF antennas...top will have a tall LED anchor light and led spreaders and 9 rockets, plus the enclosure "treads".
I have an appointment for May 4th at 8am to drop off the boat with a fiberglass repair shop. I expect them to first repair all the screw holes from the removed bimini top and the radar arch, then repair any nicks or cuts in the fiberglass, then replace the transom metal bracket. Then, do a FULL inspection of the entire boat and repair any and all issues. If we can afford it, we will get them to buff or at least strip and prep it for ME to buff and wax.
I have all new boat stickers, including the new name, "Cow Bell / Cedar Creek, TX". Yes, I know it is not a "port" but it is where we are from, and I think that is more important as to where we "hail from"... heh. If nothing else, people will ask, and we make new friends.
I got like 5-5.5" tall boat name stickers, like 3-4" tall hailing port, and 4" tall...maybe 3.5" tall...I forget, boat registration stickers.
My goal is: Get it ship shape, get the top on, clean her up... then, christen her with her new name.
I need to figure out where and how to register the actual name.. heh
I also, after the fiberglass is done, plan to find a GOOD Yamaha tech I can trust.. and have those engines inspected. This winter, if money is there, I plan to clean the cowlings and repaint them so they look solid, with new stickers. Debating white or standard color.
FIRST: Ship shape... replace and repair anything that is not "right"... worry about cosmetics later.
So... onward and upward and will update as I go!
The tractor top is down as I wanted to see if it would fit in the garage.. heh
Russ
Russ
