330 - Refinish cabin floor?
Bayhouse
My teak and holly floor is pretty beat up and I wonder if anyone has refinished theirs and have some tips/tricks for the job? I've searched and only found reference that the T&H may only be a veneer which means sanding/refinishing may be out of the question. If there is no option, i may just order Sea Deck to go over the top.
Reactions: Angler Management
It is a veneer with a plywood base. You can try to lightly sand and refinish (not sure why you wouldn't as you can always pull up). I believe it is bonded to the fiberglass floor and you can get it out if needed.
Halfhitch
Venice, Florida
That would be a shame to cover that beautiful wood. Usually that enhanced veneer is thick enough for at least a couple of judicious sandings.
Motivator
Due to delamination, I had to remove mine. Was a labor intensive job. Replaced with a more substantial piece that we epoxied on the sides and bottom to hopefully prevent another episode of delamination. Boat is a Sailfish 282.
Bayhouse
Thanks all, I'm going to try to give it a good sanding and if that doesn't work, move on to plan B
Aquanut2
Beaufort NC
@Bayhouse how did you make out refinishing your floor? Restoring an 04 Marlin and looking for steps and materials to use to get this back in shape.
Mike
Aquanut2
Beaufort NC
I'm interested in what everyone recommends using, your advise and the steps / material I should use to refinish my floor? Is Epiphanes clear varnish the best product? How many coats? after sanding is there anying I could put down first to restore the wood and color?
Mike
If I did it, I would lightly sand and use a good spar varnish.
Aquanut2
Beaufort NC
Thanks I am going to sand the whole thing and put 5 plus coats of Epifanes Clear Varnish down. Found a lot of info on how to do it by cutting it 50 - 50 with mineral spirits. Will post the results back here for other's benefits.
O
oliver305
Guest
You should lightly sand and use TotalBoat varnish, I have been looking for the varnish that has a perfect balance between tint and gloss, and I finally found it in this product.
Bayhouse
I never got around to that project and have now sold that boat. Good luck, mine looked like yours.
