- Jun 5, 2020
- Age
- 62
- Santa Cruz Mountains, CA
- Website
- mcvoy.com
- Seafarer
Take a peek at this: http://www.mcvoy.com/lm/boat/.slide-2020-06-14-12.03.24.jpg
That's my brand new Pacific trailer. As you can see the post that holds the bow is all messed up.
It wasn't originally like that, it was more forward with the 2 ubolts spread out. It moved back today when I was cranking the boat up.
I believe it is put together wrong. There needs to be on the side of the post towards that back of the boat. But you can see they didn't leave a tab there, my guess is someone welded it too close to the end of the plate, went to put the ubolt in the right spot, couldn't, shrugged and said "this will be good enough".
I originally bent it a couple of trips ago when I did the drive the truck to 3-4 mph, hit the brakes, slide the boat forward. Boat slides a little too good
I had it back at the dealer and he tried to bend back a bit and wagged his finger at me for sliding the boat like that. OK, my bad, I guess.
Except I was driving home and thinking about the fact that that post is the only thing that holds the boat from sliding forward. It has to be designed to hold the whole weight of the boat in an emergency stop, right? The straps on the back keep it from sliding backwards, that post is the only thing for the forward direction. So it should be perfectly fine to get a little speed an stomp on the brakes to move up on the black stop. The force from an emergency stop is going to be way more than a 3-4mph -> 0mph stop.
I looked at the trailers in the harbor today and they all had both sides of the post fastened down. I'm gonna ask my dealer for a new post and one that is beefier, this one is no bueno.
