- Oct 18, 2013
- Age
- 64
- Farmingdale NJ
- Overnighter
I'd touched base on this earlier and have decided to follow thru.
When tied up at the ramp waiting for me to park my truck or dunk the trailer after a day on the water the boat has a way of pivoting in with the bow rubbing on the dock marring the gelcoat. This happens even If I ask someone to watch it :roll: so I've been using the orange ball up in where the bow flares and it does the job protecting the bow. I don't really like hanging it off the rail though and figured I'd add a cleat on both sides just over the registration decal.
These are the cleats I picked up. They are identical to the factory cleats but about 3/4 in size.
I was planning on using large screws to secure the cleats as I thought that that area was inaccessible from underneath but today I went to put something in the cabin and noticed there is a gap. Its small but I can just about fit my arm thru so I broke out the inspection camera to have a look.
this is what I saw...
You can see where the railing support is thru bolted and even the reg numbers glowing thru.
There's not a lot of room there for my arms but with the help of the inspection camera to guide me I can reach a socket on an extension. Maybe get my neighbors kid with his little arms to reach up there to start a washer and stop nut on the bolt.
I had a look at the rear cleat to see how the factory bolted it up and its not all that fancy. Doesnt use a backing plate or even fender washers so I guess what I'm planning will be more than strong enough.
(you can see the cleat is the same exact style I'm installing)
I've got to go shop for hardware now. How thick do you suppose that portion of the rail deck is?
It looks to have a core glassed in so I'm guessing 1" maybe 1-1/4" ?
I plan of involving 3M5200 to seal it up as well.
