- Nov 9, 2022
- Express 265
For those of you that have redid your dashboard or switch panels, how did you attach the new material to the fiberglass? I was thinking of using the blind inserts so that i can remove them easily. Basically, just 5200 the insert into the fiberglass hole and then screw into it. The purpose of this is that my fuse panel is under one of the gauge panels on the 265. If a fuse blows, i want to be able to remove the panel easily to replace. The reason that i am thinking this is because while removing the existing panels i think that every screw broke or was so seized up that i'm hoping to avoid this in the future.
thoughts?
Stainless Steel #8-32 Blind Standoff
www.boatoutfitters.com
thoughts?
