I have a 24" Explorer (1994) with a 24"x52" deck plate over the forward fuel tank in the area of the helm. When you'd walk on the plate, it would sag a little, so I took it off for inspection. I found that the cross braces had let go from the plywood core. (Actually I don't know if they were ever epoxied to the core, or just held in place by the overlaid fiberglass fabric.) It also appeared that the fiberglass cloth was not very well saturated with resin. I also noticed that the plywood core was of different thicknesses (thinner at the edges) and not one solid piece, but made up of numerous sections. Does anyone have experience with repairing these deck plates ? Is the built up construction I've found normal ? I'm not the original owner, so I don't know if this is a standard design or someone's previous attempt to repair the plate. Any info would be helpful.
