Hello all,
I went to replace an old float switch to the bilge pump on my 1993 adventure 208. When I went to screw in the new base for the float switch, the screw actually broke off a piece of fiberglass down in the bilge. There is a slightly elevated part of the hull down there which I assume was made that way specifically to mount bilge pump and float switch so you don’t accidentally make a hole in the outside of the hull. It’s a pad and looks to be about 6” wide by 12” long and about 1” tall. The material under it is soft – almost looks like fiberglass matting. I have marine-tex and am just waiting for it to warm up around here (New England) to try a repair. The damage is about the size of a dime, so not bad at all. Am I worried about nothing? There is no damage to the outside of the hull and I assume the glass is pretty thick along the keel. Is it possible that material could get waterlogged if I don’t repair it? The reason I ask is because getting to the actual spot is tough – very tight space.
I appreciate it.
Joe
I appreciate it.
Joe
