Fuel Sender and Ski Pylon
Evopro54
Mamaroneck, NY
Freedom 255
Hi guys ,
Two part question, can someone tell me the part number (or at least the length) of the fuel sender for a 2011 Freedom 255? I will remove it and check but I figured it was worth a shot to ask.
More importantly - what does everyone do to plug the hole left in the transom once the ski pylon is removed? Right now I have a ~4” hole that allows water to flow on top of my batteries.
Thanks in advance
ilmmct
Wilmington, NC
Not entirely sure if this will work for you, given the location. But in an old rowboat I cut an access hole to fix a leaking spot at the bow eye. After the repair I found a Tempress access hatch that closely matched the hull color and fashioned a little storage that I didn’t have before. I didn’t want to learn how to repair and try to match 20-year old gel coat.
