How to Clean Hydraulic Steering Fluid from Fiberglass
hinmo
Of course while taking out the steering RAM I am replacing, I spilled fluid all over the engine well. Any advice for cleaning? My local mechanic says a strong commercial cleaner...simple green type....will do the job, but then again, his boat is a mess!
What have you tried? Did Simple Green not work? There's no special remedy here - and you really can't hurt gelcoat as long as you don't use an abrasive. SG, Dawn, acetone... whatever works.
hinmo
haven't tried anything yet, just didnt want to make more of a mess....if thats possible!
O
oliver305
Guest
I think Simple Green is good, or you can use cleaner for fiberglass such as Star Brite Ez-On Ez-Off, MaryKate MK2032 On Off,...
The longer you wait the harder it will be to remove the stain/ Try the mildest solution first and if that doesn't work, move on to something stronger. I would try WD40 first. Rub it around after sitting a bit. Rinse with soap and water and dry and if there are still stains, try Barkeepers Friend , the one that says it's OK for non stick pans.
If that doesn't work, you can try the On-Off options for hull cleaning. Whatever you do, after removing the stain, wax the area.
