Thanks! Looks like the change from the goofy sliding hatch to a tilting (and sealing) one will be pretty easy.
magicalbill said:Bama's right on that one..I jiggle the battery cables and if that doesn't fix it, I'm on my way to the service dept.
Daman858 said:I feeel your pain, Giorgos. I got an English sports car jones. On my second TR3, did an Austin Healy and two MGs. Your boat is really a gem. Best of luck with her.
NOTHING ELSE MATTERS said:magicalbill said:Bama's right on that one..I jiggle the battery cables and if that doesn't fix it, I'm on my way to the service dept.
I never, ever change oil in my boats or cars, maybe when younger(not that i can't do it now), but not now, too lazy, very little time for maintenance things and fishing, i'm a weekend warrior, but when it comes to bring something like that boat(or a car) back to life, i'm all ready. I will work after i get home from work till very late. I really enjoy doing it. I have restored 3 boats up to now and this one will be my fourth.
NOTHING ELSE MATTERS said:If i could only be able to remove the tank from the F233, i would be a VERY happy man. I am embarrassed to say, but i rum out of choices of how to remove the tank. I empty the 100 plus gallons had in there, remove all the foam around it and i tried almost everything but a hoist and can't get it to unstuck from the bottom of the boat.
Any ideas?
NOTHING ELSE MATTERS said:I think i'm high jacking Brian's thread. Sorry Brian.
BobP said:Think I'll jump in -
Sling and lift from one end only while prying there.
Get a buddy with another another pry bar, use two at a time.
gw204 said:Guys on the ClassicMako say they have good success with jamming a 2x4 in between the tank and stringers and prying on it in an attempt to shift the tank sideways and break the foam bond that way.
If prying doesn't work, stick two pieces of 1x4 in the gap and then hammer a wedge in between them.
Set up where the tank baffles are. The tank will be strongest there and will resist buckling.
ahill said:Wild guess never tried.
Take a long piece of leader wire with a dowel handle on each end. Work it under either end of the tank and saw it back and forth pulling toward the opposite end of the tank.
This should cut thru what's holding it down.
Halfway thru try the wedge technique.
Post results, I may need to try it myself.
