Quick Thru Hull Q
Blaugrana
Bayville, New Jersey
My thru hull on the port side going to the seat has a small drip where it screws into the splitter for the ice boxes (brass meets the plastic). Are there any quick fixes outside of replacing it? Dripping slightly from the bottom of the connection.
My plan is to replace when I take the boat out in the fall
Blaugrana
Is that the stay afloat stuff? I have that and rescue tape on the boat. I was debating on loading up silicone and then using the tape. It’s not too bad, but feels like condensation and drips slightly.
Blaugrana
Thanks...I have seen that used a lot. What other purposes does it serve? New Thruhulls or just the connections for the hoses?
Going to buy that for future use
Sdfish
San Diego, California
I use boat life as a sealant and for bedding hardware, above or below waterline. I am only suggesting you use boat life as a temporary fix to your small drip above. You need to address the root cause.
Blaugrana
Agreed. I need to start finding all of the parts I need to replace all of the thru hulls and how to unseat them
Recoil Rob
CT Coast
I've worked on spas, hot tubs, whirlpools for years, lots of metal into plastic work. Rare is the occasion a leak can be repaired by smearing something on the outside.
More likely the problem is the female nylon tee has begun to split from the bronze male fitting and only replacing the tee will fix it.
