- Oct 4, 2009
- Pass Christian, MS / Baton Rouge, LA
Saturday night I put my 283 on my lift, lowered the engines and turned the Perko switches off. Before I got out of the boat, I noticed that the indicator light on the aft bilge pump was lit.
I thought this indicated that the pump was running but I could not hear it. I put the switch in the on position and the entire accessory panel lit up and the pump started to run. There was no water in the bilge. When the aft pump switch is on, all accessories will work even though the Perko switches are off. When I turn the aft pump switch off, the panel looses power except that the light indicator is still on.
No mater what I did, I could not get that indicator to go off. I know the bilge pumps are wired direct to the batteries through the float switch but I cannot guess how that could power the entire accessory panel.
Anybody have any thought?
