Thru Hull transducer
OutReach
Grady White Model
Hi, I’m new to this forum, I bought a GW 1995 272 Sailfish last July, and I’m now updating all the electronics. I’m installing the nss12 evo3 with 4g radar. I fish in So Cal, and thinking of using a B75M thru hull and the active imaging 3 in 1 transom mount. My question is if I mount the B75M at the transducer flat area indentation will it work or will there be to much water disturbance for it to work. Also is there any other suggestions for transducers, the trailer has rollers so it needs to be low profile.
Jim
Denko
SE Michigan
Grady White Model
I'm not sure about transducer location on your boat, but for what it's worth the airmar thru-hulls are supposed to be able to support quite a bit of weight. With that said I don't think I'd want mine resting on a roller long term...
OutReach
Grady White Model
Thanks for replying, I talked to a GW dealer and he said the B75M won’t work in the flat transducer area, to much disturbance so I will have to put it in another location.
Doc Stressor
Homosassa, FL
Grady White Model
It's best to mount a 20 degree B75 on the V portion of the hull near the centerline. Anywhere aft of the hull's midpoint is usually fine. Avoid any flat areas including the strakes. These parts of the hull are intended to lift the hull, so they grab a lot of air and turbulence.
Papa J
I have a 1998 272 and use a B285H-W if your going to spend that much on new electronics dont cheap out on the transducer. Im in So Cal as well (San Diego) and if you want to see mine it's on a trailer. Plus Im on Simrads Pro-Staff Ill help you get it dialed in.
Sdfish
Great to see others from San Diego and So Cal on this forum! I'm in San Diego as well.
Papa J - do you support other electronics? I'm mostly interested in Garmin Echo 9sv and hooking it up to an older Raymarine S1000 autopilot.
OutReach
Grady White Model
OutReach
Grady White Model
Thanks for the reply, I went with the B75M and the 3 in 1 transom mount and installed them about 2 weeks ago, although I haven’t taken the boat out yet. I could use some help dialing it in.
Papa J
Im on Simrad Pro-Staff so I don't really know much about the other brands., If your electronics are NMEA 2000 then it probably wont work. You would have to convert to NMEA0183 then you should be able to use the AP and Nav together. I am assuming the goal is to have your AP go to a specific coordinate on the chart plotter?
Sdfish
Im on Simrad Pro-Staff so I don't really know much about the other brands., If your electronics are NMEA 2000 then it probably wont work. You would have to convert to NMEA0183 then you should be able to use the AP and Nav together. I am assuming the goal is to have your AP go to a specific coordinate on the chart plotter?[/QUOTE
Thanks, yes that's what I am. Trying to do. I think the easiest way would be by direct bare wire connections.
