- Mar 5, 2019
- Age
- 58
- Islander
The truck specs it's max towing is 9200.
I did add it up, and yes the truck will tow it. The issue comes in, and most people simply do not look and thus never know or realize, not all tow packages are the same.
The "truck" CAN tow 9200lbs, given it's 5.0 liter engine and the 3.55 axle ratio on a Supercrew. If you look under the truck, at the trailer hitch itself, the 2"x2" receiver, it clearly states that it can tow a maximum of 5000lb or 500lbs tongue weight, unless you have a weight distribution hitch, at which point it goes up to 11,600 and 1160, respectfully.
Also, to note, so many folks go to the hardware store or wherever.. see a 2 5/16" ball attached to a slab of metal. It fits in the 2x2 receiver and BAM! they are up and towing... having never looked and saw they added the right "size" ball.. but then go and add a 7000lb boat and they hit a bump and snap it off. Just because they have towed without an issue, does not equate to doing it right.
I love the input, hence why I asked for it.. heh.. and I appreciate it.. but I have a lot of experience as well. I ask to make sure I do not miss things, and make sure I get quality when I add something. I do not always get that.. lol.. I am human.. I have bad luck too ..
but.. as I keep stating, this is not just about getting what I need, it is me, with my experience pulling things, trying to make sure I cover all bases.
Personally, this time.. I may be sending back the WD hitch.. it may be more than I care to deal with as air bags I can lower.. the WD.. that may turn out to be more of a pain in the neck than anything else... but, I think adding the 10klb hitch/receiver is key to making this a smoother ride.
The hitch currently on the truck is not rated to handle this boat unless I add a Weight Distribution hitch. Since I have the air bags, I think I can do without the hitch... we will see.
but... (there is always a but.. lol)....if I do not use the WD... and use only the current stock hitch, and something happens.. I guarantee I will not be able to contest if insurance decides not to cover an accident. So.. I will add the 10k hitch and all will be well with the world
Thanks!
R
Thanks!
R
