I took the aluminum molding off around the transom (of my 82 Seafarer outboard)and the fiberglass has cracked and broken away where it meets at the edge ! It almost seems as if the wood inside probably swelled a bit and then caused it to break and then start to pull away from each other about 1/16 of an inch ! I am assuming that I am not the only one that this has happened to cause' it looks like a poor design. My question is what do I do about it ? I think the transom is solid (at least it appears to be) and when I jump up and down on the outboard cavitation plate it does not appear to flex much. The boat is on the trailer.
I was thinking of just cleaning up the jagged break and caulking it cuz I am guessing that by just glassing over the break it will just break again and keeping water out is the main concern - but I am no expert. The aluminum probably needs to be re-drilled in spots and maybe I will use those "saucer" looking washers to keep the screw heads from pulling thru again in spots.
Has anyone tackled this project at all ? Any help would be GREATLY appreciated. Thanks.
