water pump
dan313
LI, NY
Hi,
I wanted to change my water pump on my 200 hpdi. I'm having trouble getting the woodruff key out. I tried tapping, heat, pulling on it, and it just won't come off. Help :?: :?:
Thanks,
Lenny
Walkers Edge
Jupiter, Fl
When I last changed mine I had the same problem. Since the pump kit came with a new key I clamped a set of vice grips onto the key and tapped with a hammer in all directions until it slid loose.
Be careful not to mess up the key slot, tapping in parallel with shaft should reduce the risk.
Just for a consensus, when replacing impellers do you all replace the whole assembly (o-rings ,etc) or just the impeller? I usually take the more cautious route.
Strikezone
Charleston, SC
I replace the whole works while I have it apart.
Have found the dremel the best approach to a stubborn key.
dan313
LI, NY
I used a dremmel tool to remove the key. All the banging in the world would not move it. So it is now put back together and reinstalled on the boat.
Thanks for all the responses.
Lenny
JUST-IN-TIME
ON THE WATER
i had a bad one
use my little bic lighter, PB blaster, biggest punch in my box and a 10LB rubber hammer
what a pain
i filed the keyway and used a ton of grease on the new one
problem is yami uses stainless on driveshaft and a dissimilar metal on keyway
go figure
Lainie J
Pump
What are you guys paying for the water pump for a 225HP Yamaha four stroke? I really dont like doing myself. I have a local shop that will do them for $275 ea.
