What Props for a 330 with F300's?
HMBJack
Half Moon Bay, CA.
I will be doing a repower this Summer on my 2006 330 Express.
Wondering if anyone has some real world experience on their propeller selection on a 330 with twin Yamaha 300's.
I'm thinking Yamaha's Salt Water Series in a 17 pitch, 3 blade, is a good place to start.
Curious what others think in this exact set-up: a 330 with F300's (i.e. not Suzuki's, not a Marlin, etc.).
Thank you...
wspitler
Inglis, FL
I just re-powered my 2007 330 with F300s. I initially used the same props that I had on my F250s, 17 pitch. Of course the F250 has a different gear ratio than the F300. 2:1 vs 1.75:1 At any given RPM the F300 turns the prop faster. With a heavy load I could only get 5400 RPM at WOT with the 17 inch props. I looked for a set of 16 inch pitch to get my top end a little higher, but could not find a pair. I opted for the prop that Grady-White puts on the boat at the factory which is a SSII SDS 15 3/4 diameter by 15 inch pitch and my top end RPM is now 5800 with a medium load. I may have lost a little bit of efficiency, but it feels more comfortable. When I first tested the 17 inch props that came off my F250s, I was told by a technician who worked at the factory for Yamaha doing prop selection testing that I needed to get a little higher wide-open throttle to be kinder to my engine. I have kept both sets of props and am currently running the SSII SDS 15 pitch. As I get more experience, I may put the 17s back on and try to do exact comparisons if I can get the conditions. Haven't been out in heavier seas, but GW has done testing and made their choice which I am sure is a compromise. It does seem I may have lost a slight amount of nautical miles per gallon by switching to the lower pitch. Hope that helps!
HMBJack
Half Moon Bay, CA.
Thank you very much.
I wonder if a set of 4 blades in 16 pitch would be best.
but I prefer not to guess…
ElyseM
highlands, nj
can't help directly. but 4 blades on my '09 330 with f350's was night and day. improvement all around except for top speed (which i don't do anyway). good luck, ron
everwhom
Cape Cod and Nantucket
I've been wanting to try the 15 inch Powertech OFS4 on my 4.2L F250's (detuned F300) to see if they improve cruise economy (I also don't give a hoot about top speed). Right now I have 15 inch Mercury Mirage props on my 330 and I get 1.1 mpg (statute) at 4300 RPM and 29mph as best cruise. Top speed is about 39 at 5400 RPM.
HMBJack
Half Moon Bay, CA.
Reading the above, I think I might try the props I currently run on my 3.3L F250’s. They are PowerTech Offshore 4 blade props that are 15.25” diameter in 16 pitch.
These props work well on my F250’s. I think they will work well on the F300’s. ?
