- Nov 13, 2009
- Homosassa, FL
- Seafarer
I need to replace the wiper motor on my 226. This was a piece of cake on my older Gradys that had externally mounted wiper motors. But my 2008 has the wiper shaft going through the deck and the motor is located behind a cover on the inside of the cabin.
Before I start taking things apart, has anyone replaced the motor on a Grady with a similar location as on my 226?
It looks like all I need to do is to remove the wiper blade and the nut on the shaft and then remove the single nut on the motor bracket mount on the inside. But it's 90+ degrees outside with stifling humidity, so I'd like to keep this job as simple and fast as possible.
