- Oct 12, 2017
- Manasquan Inlet NJ
- Website
- www.youtube.com
- Express 265
I don't use Teflon tape on gasoline fittings. I use a gasoline approved paste. It's not that the tape gets dissolved as best I know but rather that the fittings can loosen up due to vibration.Finally got around to installing these. These are direct match to OEM Grady 2000 265 express.
1/4" FNPT 3 way fuel selector-Moeller 033302-10
Don't be fooled by others. These are what you need.View attachment 36899
Where did you get it?Finally got around to installing these. These are direct match to OEM Grady 2000 265 express.
It’s yellow gasoline tape not TeflonI don't use Teflon tape on gasoline fittings. I use a gasoline approved paste. It's not that the tape gets dissolved as best I know but rather that the fittings can loosen up due to vibration.
Wholesale marine warehouseWhere did you get it?
I am sorry for even suggesting you used the wrong stuff. I should have known betterIt’s yellow gasoline tape not Teflon
Haven't run them yet so idk if it leaksI am sorry for even suggesting you used the wrong stuff. I should have known better![]()
Yes, pointer is opposite the handle. Center is Off.Every year I second guess myself on this tank selector switch (don't have a label above the valves). Primary tank is pointing the valve aft and the pointer is opposite of the handle, correct?
On many hulls, the aux tank is forward. There is no absolute rule. There can be an advantage to having the aux tank forward and that is as fuel is used off of the main, the center of flotation of the boat shifts forward which can be preferable to shifting aft as would be the case in a aft mounted aux tank. Of course this assumes that the main is used first and then the aux.Yea its the same. Always confused why they would make the primary tank pointing right or pointing aft when the primary tank is forward. Thanks!
This is the case with my 228. Aux tank is forward. I rarely fill my main up unless I'm going to be leaving the boat in the water for any length of time such as my Keys trip for the week. I will run off my main tank until the fuel level lights start blinking, then switch to the aux tank. Keeping aux tank full and mainly run off that one any other time ,helps with overall ride keeping the weight more central in the boat than all the way in the back, if I used the main tank instead. My valve is the original one and is still functioning.On many hulls, the aux tank is forward. There is no absolute rule. There can be an advantage to having the aux tank forward and that is as fuel is used off of the main, the center of flotation of the boat shifts forward which can be preferable to shifting aft as would be the case in a aft mounted aux tank. Of course this assumes that the main is used first and then the aux.
Exactly! It depends on what the Captain decides to do.On many hulls, the aux tank is forward. There is no absolute rule. There can be an advantage to having the aux tank forward and that is as fuel is used off of the main, the center of flotation of the boat shifts forward which can be preferable to shifting aft as would be the case in a aft mounted aux tank. Of course this assumes that the main is used first and then the aux.
