Filling holes..........
FraJul
So I have a 2004 265 Express and am planning to remove an old transom mount transducer. What would be the best way to fill the screw holes that are under the water line. I also plan to take an old spotlight and megaphone off the roof. Thanks in advance for your respsonse. Frank
andyb
James Island, SC
I typically clean out the holes with an appropriately sized drill bit just slightly larger to ensure a good clean surface, then use a stepped bit to create a little bit of cone shape in the head of the hole, then fill with west systems six10 thickened epoxy. If the screw holes are really small, I shoot the west systems thickened epoxy into a syringe to be able to get all the way in to the back of the hole. Fill from the back of the hole out to the front making sure no air is trapped in the hole. Level off the excess that comes out.
leeccoll
Reno NV
Epoxy into the wood, finish off surface with marine tex, sand down smooth.
Reactions: Meanwhile
Filling with epoxy, as mentioned above (whether you buy pre-mixed or make your own) is definitely the "best" way. The syringe trick is important. If your boat is bottom painted, just paint over the epoxy after you get the area "somewhat" smooth.
After injecting the epoxy, put a piece of tape over the hole to make sure it stays there. I've also used un-thickened epoxy by creating a "dam" over the hole - just another way to do the same thing.
FraJul
I tried 5200 and it sort of slumped out of the screw holes overnight. Gonna sand and drill them out a bit and try the six 10 epoxy
RussGW270
I am guessing the epoxy will work well for a couple holes left in my cockpit when we removed the bimini supports.
Almost ordered that dang Thixo... it threw the generic version in the cart.. heh
andyb
James Island, SC
Taping over the bottom half of the hole like DennisG mentioned definitely helps if the epoxy tries to slump out. Doesn't take much to work, painters tape or duct tape works just fine.
Sdfish
San Diego, California
I recently did this on my boat. Follow Andyb's advice on cleaning out the old holes. I used MarineTex on my holes since it was is white, but have also used epoxy in the past.
As mentioned, make sure the hole is clean. Drill out a bit if necessary It is not a good idea to insert a piece of wooden dowel soaked in epoxy as some other sites have suggested.
Harpoon
I'd sand the gel coat down in that area, fill with six 10, then put layup over the entire section. Smooth then gel coat.
I'm going to assume that there are three closely spaced holes and probably some older holes from previous transducers
Unfortunately,as others have said, yes you have to make the holes bigger and clean to fill them correctly....just epoxy from a 2 part syringe, or thickened epoxy(you have to buy way more filller than you will need), or polyester resin.
I'm going to assume it has bottom paint, in which case it doesn't have to be pretty so I would finish with a layer of glass over the area. (You will have to sand clean the whole area)
If you plan on adding a new transducer, consider wrapping a piece of plywood in glass and glassing it to the area. Now your new screws don't go into the transom...
FraJul
So in the end I used the six 10 epoxy and finished it with spectrum patch paste. Very happy with results.
Sdfish
For reference here is a picture of marine tex filling old holes. I didn't try to make it pretty - below the water line. I may come back at some time and sand it down and cover it with gel coat - when I fill the other nicks and scratches on the boat.
You could fine sand that down and gelcoat over with a touch up kit if desired.
